  • 1 Vote(s) - 1 Average
Growing up quick...with a 38-690xx Pics added.
#34
32-7115
5.25 H, 125 DC mA, 170 ohms DC resistance.
Hammond's 159P is probably as close as you can get without having one custom wound - 10 H, 125 DC mA, 155 ohms DC resistance. Open frame, not enclosed. Maybe the 159P might fit inside the 32-7115 shell? You can take the measurements from here and compare with yours:
http://www.hammondmfg.com/153.htm
RE: Growing up quick...with a 38-690xx Pics added. - by Ron Ramirez - 02-23-2013, 03:43 PM
Users browsing this thread: 13 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6763 online users. [Complete List]
» 1 Member(s) | 6762 Guest(s)
