  • 1 Vote(s) - 1 Average
Recognize this Philco globe? RESOLVED/THANKS
I do have a set on the bench right now with 42s. What's the worst that could happen if it's not a 42?
RE: Recognize this Philco globe? - by 7estatdef - 02-22-2013, 05:33 PM
RE: Recognize this Philco globe? - by Ron Ramirez - 02-22-2013, 07:06 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-22-2013, 07:08 PM
RE: Recognize this Philco globe? - by 7estatdef - 02-22-2013, 08:52 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-23-2013, 11:16 AM
RE: Recognize this Philco globe? - by 7estatdef - 02-23-2013, 12:01 PM
RE: Recognize this Philco globe? - by Conelrad - 02-23-2013, 02:44 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-23-2013, 04:45 PM
RE: Recognize this Philco globe? - by 7estatdef - 02-23-2013, 06:37 PM
RE: Recognize this Philco globe? - by Conelrad - 02-24-2013, 08:47 AM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-24-2013, 01:02 PM
Philco 91 Tuning Condenser
