Early Model 65 Highboy
Thanks Ron, I know the price is high but one has to take into consideration the cost of shipping. Your right, Arizona is the desert area of radios out here. What the hay, I'm going for it. We will see if he takes my offer. Yes, I'm an old Philco Phan. This could be my earliest. I like the 31s. Might even go as new as the 38s.
Jerry
Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 06:28 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 06:58 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 07:51 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-23-2013, 08:12 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 08:45 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 11:57 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 02:01 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 11:16 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 12:12 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 02:20 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 08:27 AM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 09:15 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 09:21 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:06 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:29 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:42 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:53 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 06:01 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 06:20 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:07 PM
RE: Early Model 65 Highboy - by Phlogiston - 02-26-2013, 09:27 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:45 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-26-2013, 09:50 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 10:04 PM
Philco 91 Tuning Condenser
