Antenna for 39-116
Hi
Model 39-116 was not manufactured with a loop antenna; it was designed for a longwire. Of course the "Mystery Control" section of the receiver DOES have a loop antenna, built into the bottom of the cabinet.
Some people have made their own in-cabinet loops for consoles. Some of these folks report good results. YMMV. I would opt for the longwire, or at least a short length of wire stretched across the baseboard of one or two walls.
Antenna for 39-116 - by lew-g - 10-25-2007, 03:32 AM
[No subject] - by Ron Ramirez - 10-25-2007, 05:40 PM
[No subject] - by lew-g - 10-26-2007, 12:20 AM
Philco 91 Tuning Condenser
