New guy, with a Philco question.
Hi. Thanks for having me.
I just purchased a Philco PT-7 for $20. Can somebody tell me a little about this radio? I'm assuming the P stands for Philco., the T stands for table, and the 7, I have no idea.
Thanks you.
New guy, with a Philco question. - by Guest - 10-25-2007, 08:33 PM
[No subject] - by Ron Ramirez - 10-25-2007, 09:25 PM
[No subject] - by Guest - 10-25-2007, 09:27 PM
Philco 91 Tuning Condenser
