Early Model 65 Highboy
Yes Terry, 500 for a 37-116 seems a little stiff. Local pickup a little better. I have the chassis for a 38-116 on my bench now. Finishing it up for my friend. He got it for free. Wish I could find a deal like that. I only want a small number of radios but like to pick out ones for replacing others. The 116 on my bench is just a splendid radio although I have not seen the cabinet. My friend will restore that. Just shows some get lucky on price. The style of those radios don't really trip my trigger. I like the highboys with the spindle legs. To each there own and at my age, and financial situation money means little. Of course, I don't want to be screwed. Just having fun.
Jerry
Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 06:28 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 06:58 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 07:51 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-23-2013, 08:12 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 08:45 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 11:57 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 02:01 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 11:16 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 12:12 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 02:20 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 08:27 AM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 09:15 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 09:21 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:06 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:29 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:42 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:53 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 06:01 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 06:20 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:07 PM
RE: Early Model 65 Highboy - by Phlogiston - 02-26-2013, 09:27 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:45 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-26-2013, 09:50 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 10:04 PM
Philco 91 Tuning Condenser
