41-250 alignment procedure
Terry I'm in Shenandoah Heights about half
Way between Pottsvile and Hazleton.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
41-250 alignment procedure - by 462ron - 02-23-2013, 09:59 PM
RE: 41-250 alignment procedure - by gvel - 02-24-2013, 12:51 PM
RE: 41-250 alignment procedure - by 462ron - 02-24-2013, 05:11 PM
RE: 41-250 alignment procedure - by 7estatdef - 02-24-2013, 07:03 PM
RE: 41-250 alignment procedure - by 462ron - 02-24-2013, 09:46 PM
RE: 41-250 alignment procedure - by 7estatdef - 02-25-2013, 12:30 AM
RE: 41-250 alignment procedure - by 462ron - 02-25-2013, 05:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
