Early Model 65 Highboy
Simple - he saw an identical model 95 on eBay for which some clueless seller had set a starting bid or a Buy It Now of $650 or so, and now he thinks he has a rare and very valuable treasure.
You cannot reason with folks like this - it is best to go find another one elsewhere at a more reasonable price.
Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 06:28 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 06:58 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 07:51 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-23-2013, 08:12 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 08:45 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 11:57 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 02:01 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 11:16 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 12:12 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 02:20 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 08:27 AM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 09:15 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 09:21 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:06 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:29 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:42 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:53 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 06:01 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 06:20 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:07 PM
RE: Early Model 65 Highboy - by Phlogiston - 02-26-2013, 09:27 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:45 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-26-2013, 09:50 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 10:04 PM
Philco 91 Tuning Condenser
