Early Model 65 Highboy
Those early sets are difficult to tell what model it is without seeing a pic of the chassis as several chassis can be fitted to the same cabinet. About the only way to tell is to know how many tubes it has and if they are triodes or screen grid tubes. If you know that then the only thing at can throw you off is the output tube some use 71's or it could use 45's.
Ron types much faster than I.
Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 06:28 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 06:58 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 07:51 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-23-2013, 08:12 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-23-2013, 08:45 PM
RE: Early Model 65 Highboy - by Arran - 02-23-2013, 11:57 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 02:01 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-24-2013, 11:16 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 12:12 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 02:20 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 08:27 AM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 09:15 AM
RE: Early Model 65 Highboy - by jontz - 02-25-2013, 09:21 AM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:06 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:29 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 05:42 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-25-2013, 05:53 PM
RE: Early Model 65 Highboy - by 7estatdef - 02-25-2013, 06:01 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-25-2013, 06:20 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:07 PM
RE: Early Model 65 Highboy - by Phlogiston - 02-26-2013, 09:27 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 09:45 PM
RE: Early Model 65 Highboy - by Ron Ramirez - 02-26-2013, 09:50 PM
RE: Early Model 65 Highboy - by jerryhawthorne - 02-26-2013, 10:04 PM
Philco 91 Tuning Condenser
