Philco 38-10 Q
Be very careful sanding photo finish.
I have had good results using 0000 steel wool on photo finish. The object is to clean/smooth the old finish, then spray clear lacquer over it.
Philco 38-10 Q - by Rubrburnr - 02-23-2013, 09:00 PM
RE: Philco 38-10 Q - by Rubrburnr - 02-23-2013, 10:01 PM
RE: Philco 38-10 Q - by TA Forbes - 02-26-2013, 01:34 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1865 online users. [Complete List]
» 1 Member(s) | 1864 Guest(s)
