Model 20 power transformer
Happened to have a 1941 Philco catalog (on PDF) handy, here's the specs of your power transformer:
5-3/8" high, 3-7/8" wide, 3-1/4" deep. You'll need to measure the spacing between the mounting holes on your transformer.
Primary - 110 volts, 50-60 cycles. (For your new one, specify 125 or 130 volts for the primary.)
High voltage - 700 volts center-tapped (also known as 350-0-350V), 80 mA DC
Filament #1 - 2.5V center-tapped, 7 amps
Filament #2 - 5V center-tapped, 2 amps
Filament #3 - 5V, 2 amps (for rectifier filament, no center tap)
Model 20 power transformer - by Danny - 10-26-2007, 11:03 AM
[No subject] - by Ron Ramirez - 10-26-2007, 03:10 PM
[No subject] - by Ron Ramirez - 10-26-2007, 03:17 PM
[No subject] - by Danny - 10-27-2007, 12:11 PM
[No subject] - by Ron Ramirez - 10-27-2007, 12:35 PM
[No subject] - by Danny - 10-27-2007, 02:28 PM
[No subject] - by davemc - 10-29-2007, 12:08 PM
[No subject] - by Terry Judkins - 10-29-2007, 07:47 PM
[No subject] - by davemc - 11-02-2007, 07:02 AM
[No subject] - by Danny - 11-10-2007, 01:17 PM
[No subject] - by Danny - 11-16-2007, 07:12 PM
There are currently 9613 online users. [Complete List]
» 1 Member(s) | 9612 Guest(s)
