  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
Eliot (John) - Thanks very much for the link! Icon_thumbup Very good info. Unfortunately, this circuit is designed for 100 mA max B+ current. With 21 tubes, I suspect the MP VI will be running more like 150-200 mA. I'll email Leigh and ask his opinion. He is doing a great work with his Atwater Kent info and schematics website.
http://www.atwaterkent.info/
Arran - That is a neat Magnavox speaker! Too bad it's a 15 and not an 18, though. Yes, it's expensive, but if that were a 1930s Jensen instead of a 1930s Magnavox, it would have been gone within minutes of its posting at that price.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by Ron Ramirez - 02-26-2013, 04:52 PM
Users browsing this thread: 13 Guest(s)
There are currently 10845 online users. [Complete List]
» 2 Member(s) | 10843 Guest(s)
