1948 Philco Transitone model 48-250
Quote:All my dud tubes are drying a fresh coat of red paint as I type this.
Gonna make a bundle selling 'em on eBay!
Oh no, Tom, you want to paint your tubes blueIcon_lol
M R Radios   C M Tubes
RE: 1948 Philco Transitone model 48-250 - by Steve Davis - 02-26-2013, 08:14 PM
Philco 91 Tuning Condenser
