Anybody know what make this radio is?
Here are a few pictures of my FM12A. The chassis is done, but as you see, the cabinet has issues. I have yet to see another. I have asked on ARF for pictures of another, with no response. I have also searched the net and I have only found a few B&W advertisements. If anyone has one I would appreciate any pictures.
RE: Anybody know what make this radio is? - by Skip - 02-26-2013, 09:11 PM
RE: Anybody know what make this radio is? - by 4allofyou - 07-01-2013, 04:47 PM
There are currently 6443 online users. [Complete List]
» 2 Member(s) | 6441 Guest(s)
