Unmarked paper caps on the early 16X chassis
There are two unmarked paper caps on the 16 chassis part number 30-4020-X that are shown on Riders but no value listed. Can anyone say what the value are for these two paper caps.
Unmarked paper caps on the early 16X chassis - by 49Stude63 - 10-27-2007, 10:34 PM
[No subject] - by Ron Ramirez - 10-27-2007, 11:09 PM
Philco 91 Tuning Condenser
There are currently 9056 online users. [Complete List]
» 1 Member(s) | 9055 Guest(s)
