Philco model 18 (code 121) - HELP!
Threads: 1
City: Sunny Michigan
Jerry, I just read up on the signal generator. I see it says the AF-In goes to the ground of Chassis (like you said) and the RF - goes to the Antenna wire.
As far as modulation turned 'ON' (as you say) my options are either 'EXT.' (on the left side of the switch) or turning the switch to the right for 'INT'. Which way would be the same as 'ON'....I'm leaning towards 'INT'???
RE: Philco model 18 (code 121) - HELP! - by Pithicus999 - 02-27-2013, 12:50 PM
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
