Unmarked paper caps on the early 16X chassis
Hi Stude
30-4020 is .05 uF. Icon_smile
[No subject] - by Ron Ramirez - 10-27-2007, 11:09 PM
Philco 91 Tuning Condenser
There are currently 8842 online users. [Complete List]
» 2 Member(s) | 8840 Guest(s)
