  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
I would have used lockwashers as well as threadlock, but your experience may vary.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by codefox1 - 02-28-2013, 12:23 AM
Users browsing this thread: 15 Guest(s)
There are currently 11251 online users. [Complete List]
» 3 Member(s) | 11248 Guest(s)
