New to the forum and my first post. I picked this up yesterday at a local antique store where it had been sitting in the shop for 12 years. It's rough, but I hope to get it sounding and looking great.
KE5YUM
48-1262 - by ke5yum - 02-28-2013, 12:14 PM
RE: 48-1262 - by NostalgiaRadioTime - 02-28-2013, 07:50 PM
RE: 48-1262 - by 7estatdef - 03-03-2013, 10:57 AM
RE: 48-1262 - by ke5yum - 03-04-2013, 11:53 AM
Philco 91 Tuning Condenser
