Philco model 18 (code 121) - HELP!
Threads: 562
1. Attaching a pic;
Instead of "quick reply" press "new reply" button, it will give you full interface.
Press "New attachment" button.
Browse to the pic, choose it, then press "Add attachment" button.
Once it is added below, press "place in text" (or something like it) button.
Press "post reply".
2. F-F means "filament to filament" that is a heater voltage.
3. Big pins (fat ones) are usually the Filaments. Those also serve as the key when inserting the tube, as fatter pins won't go into smaller pin sockets.
RE: Philco model 18 (code 121) - HELP! - by morzh - 02-28-2013, 06:04 PM
Users browsing this thread: 42 Guest(s)
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
