38-690 New questions
As I progress through this radio, I find myself in need of a few things. The first of which would be a voltage chart. Does anyone have access to one of these?
Also, Looking at the dial mechanism, I can't quite figure out how to get it apart, and it does need to come apart so I can replace the dial scale (one of Mark O's great repros is on order).
I can't wait to get in my replacement e-caps so that I can get to restuffing those old cans.
38-690 New questions - by BrendaAnnD - 03-01-2013, 04:39 AM
RE: 38-690 New questions - by Ron Ramirez - 03-01-2013, 06:46 AM
RE: 38-690 New questions - by BrendaAnnD - 03-01-2013, 01:03 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
