Transporting a 37-116
Make sure the speaker is bolted down before you move or tilt the cabinet or like Ron said it will destruct the speaker. Don't ask me how I know. Seems like you can't remove the speaker before you remove the chassis. It won't clear the bottom edge the chassis.
Transporting a 37-116 - by jontz - 02-28-2013, 02:02 PM
RE: Transporting a 37-116 - by codefox1 - 02-28-2013, 03:27 PM
RE: Transporting a 37-116 - by Steve Davis - 02-28-2013, 03:59 PM
RE: Transporting a 37-116 - by Ron Ramirez - 02-28-2013, 04:55 PM
RE: Transporting a 37-116 - by jontz - 02-28-2013, 09:07 PM
RE: Transporting a 37-116 - by TA Forbes - 02-28-2013, 09:37 PM
RE: Transporting a 37-116 - by 7estatdef - 03-01-2013, 08:26 AM
RE: Transporting a 37-116 - by jontz - 03-01-2013, 05:14 PM
Philco 91 Tuning Condenser
