These folks just did this for me
Nice!
I just sent today's morning the whole shadow meter to them. Hopefully they will do an equally good job on it.
These folks just did this for me - by DKinYORKpa - 03-02-2013, 09:52 PM
RE: These folks just did this for me - by morzh - 03-02-2013, 10:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
