  • 1 Vote(s) - 5 Average
Thoughts on a McMurdo Silver Masterpiece VI Speaker
#39
Just a thought, I have used large filament transformers as chokes in the past. l just use the primary and leave the secondary open.
RE: Thoughts on a McMurdo Silver Masterpiece VI Speaker - by codefox1 - 03-03-2013, 01:31 AM
