Admiral 5D3A
I'll also add that generally the crystal cartridges are all about the same electrically so you wouldn't have to find an exact match. You may have to engineer a mounting system for it. On trash nite you'll probably find some stereo cartridges.
Admiral 5D3A - by Eric T - 03-02-2013, 08:20 PM
RE: Admiral 5D3A - by 7estatdef - 03-03-2013, 01:19 PM
RE: Admiral 5D3A - by codefox1 - 03-03-2013, 02:01 PM
RE: Admiral 5D3A - by 7estatdef - 03-03-2013, 02:23 PM
RE: Admiral 5D3A - by Eric T - 03-05-2013, 10:07 AM
RE: Admiral 5D3A - by Eric T - 03-07-2013, 07:59 PM
RE: Admiral 5D3A - by Eric T - 03-08-2013, 08:55 PM
RE: Admiral 5D3A - by codefox1 - 03-08-2013, 09:54 PM
RE: Admiral 5D3A - by Eric T - 03-09-2013, 03:02 PM
RE: Admiral 5D3A - by Eric T - 03-14-2013, 05:44 PM
RE: Admiral 5D3A - by codefox1 - 03-15-2013, 01:15 AM
RE: Admiral 5D3A - by Eric T - 05-16-2013, 08:08 PM
RE: Admiral 5D3A - by BrendaAnnD - 05-16-2013, 08:33 PM
RE: Admiral 5D3A - by GarySP - 05-16-2013, 10:08 PM
RE: Admiral 5D3A - by Eric T - 05-16-2013, 11:41 PM
There are currently 10380 online users. [Complete List]
» 1 Member(s) | 10379 Guest(s)
