Some run and hide from the '39 to'42 sets. Good observations John!
42 1008 - by Bill Kinghorn - 03-01-2013, 08:48 PM
RE: 42 1008 - by Arran - 03-01-2013, 09:55 PM
RE: 42 1008 - by Mr Grumpy - 03-02-2013, 12:27 AM
RE: 42 1008 - by Bill Kinghorn - 03-02-2013, 12:10 PM
RE: 42 1008 - by Raleigh - 03-03-2013, 02:23 PM
RE: 42 1008 - by 7estatdef - 03-03-2013, 03:06 PM
RE: 42 1008 - by Bill Kinghorn - 03-05-2013, 12:52 AM
Philco 91 Tuning Condenser
