42-380 candholm
A while back a 42-380 I have been working on smoked the bias resistor part number 33-3393-1 . I found a parts chassis and the bias resistor from it is marked 33-3393-3. It is made a little different than the original physically. My crummy sears volt ohm meter is not working, so I can't get a good reading until Tuesday when I get to work. Can anyone tell me if these two parts are interchangeable electrically? Thanks.[/i]
42-380 candholm - by Groundhog74 - 03-03-2013, 03:15 PM
RE: 42-380 candholm - by Groundhog74 - 03-05-2013, 10:15 AM
RE: 42-380 candholm - by codefox1 - 03-05-2013, 12:07 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
