Odd 41-220CI
That's a Philco factory illustration, and yes, they goofed...the set does not have a 9 to 12 mc SW band, but a 1.6 to 3.3 mc band as illustrated in the 41-220C photo just above the 41-220CI illustration.
Good eye, thanks for catching that - I must confess that I had not noticed that previously.
Odd 41-220CI - by 7estatdef - 03-03-2013, 03:01 PM
RE: Odd 41-220CI - by Ron Ramirez - 03-03-2013, 08:17 PM
Philco 91 Tuning Condenser
There are currently 3992 online users. [Complete List]
» 1 Member(s) | 3991 Guest(s)
