My new Philco-Silver combo
If the lacquer on that cabinet is less than a year old, the feet on the radio might leave marks.
My new Philco-Silver combo - by y2kbruce - 03-04-2013, 09:38 AM
RE: My new Philco-Silver combo - by Phlogiston - 03-04-2013, 11:06 AM
RE: My new Philco-Silver combo - by radio-Don - 03-04-2013, 06:24 PM
RE: My new Philco-Silver combo - by Ron Ramirez - 03-04-2013, 07:13 PM
RE: My new Philco-Silver combo - by y2kbruce - 03-04-2013, 07:14 PM
RE: My new Philco-Silver combo - by y2kbruce - 03-04-2013, 07:17 PM
RE: My new Philco-Silver combo - by Gene Pederson - 03-04-2013, 08:13 PM
RE: My new Philco-Silver combo - by y2kbruce - 03-05-2013, 06:02 PM
RE: My new Philco-Silver combo - by TA Forbes - 03-07-2013, 03:25 PM
RE: My new Philco-Silver combo - by PhilcoMike - 03-08-2013, 11:47 AM
Philco 91 Tuning Condenser
