  • 1 Vote(s) - 1 Average
Recognize this Philco globe? RESOLVED/THANKS
I've got a Philco 42 globe tube with the date code of "H 3". So, using the date code Ron mentioned gives me a date of August, 1933? I was under the impression that the glove Philco 42 was only made in 1932. Maybe I'm mistaken. Can anyone provide any clarity on this? The good news is that this tube is good and tested pretty strong.
Thanks, Tom
RE: Recognize this Philco globe? - by 7estatdef - 02-22-2013, 05:33 PM
RE: Recognize this Philco globe? - by Ron Ramirez - 02-22-2013, 07:06 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-22-2013, 07:08 PM
RE: Recognize this Philco globe? - by 7estatdef - 02-22-2013, 08:52 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-23-2013, 11:16 AM
RE: Recognize this Philco globe? - by 7estatdef - 02-23-2013, 12:01 PM
RE: Recognize this Philco globe? - by Conelrad - 02-23-2013, 02:44 PM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-23-2013, 04:45 PM
RE: Recognize this Philco globe? - by 7estatdef - 02-23-2013, 06:37 PM
RE: Recognize this Philco globe? - by Conelrad - 02-24-2013, 08:47 AM
RE: Recognize this Philco globe? - by DKinYORKpa - 02-24-2013, 01:02 PM
RE: Recognize this Philco globe? RESOLVED/THANKS - by Tom Hamilton - 03-04-2013, 11:19 AM
Philco 91 Tuning Condenser
