Got the 37-116.
Got the 37-116 we were talking about earlier in a different thread.
It will require lots of work.
I never saw a chassis that heavy. I took it out of the car and barely was able to carry it home to the second floor. It is probably good 45-50 pounds.
Chassis is mostly dirty, some rust, nothing egregious.
Cabinet has scratches.
The dial has a broken piece. (I have it).
Cabinet's chassis support inside has some damage.
In short, I have my work cut out for me.
But first I want to finish the 38-15 and my Zenith.
The 37-116 is a warm time of the year project - will require working outside.
I may make it my first ever cabinet restoration attempt.
Will need a lot of help with it. I have zero to negative experience doing that. But....I feel emboldened. Icon_lol
Got the 37-116. - by morzh - 03-04-2013, 07:41 PM
RE: Got the 37-116. - by 7estatdef - 03-04-2013, 08:05 PM
RE: Got the 37-116. - by jerryhawthorne - 03-04-2013, 08:51 PM
RE: Got the 37-116. - by morzh - 03-04-2013, 09:48 PM
RE: Got the 37-116. - by jontz - 03-04-2013, 10:20 PM
RE: Got the 37-116. - by jerryhawthorne - 03-04-2013, 10:25 PM
RE: Got the 37-116. - by 7estatdef - 03-04-2013, 11:24 PM
RE: Got the 37-116. - by morzh - 03-05-2013, 11:14 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
