Difficulty level in restoring 38-3xx
Hi Tony
The final decision is up to you, of course, but $40 is a good price for a 38-3. I say go for it! Icon_smile Yes, it will be a bit more of a challenge, but if you can fix a 38-7, you should be able to tackle a 38-3.
[No subject] - by Ron Ramirez - 10-30-2007, 07:20 AM
[No subject] - by 49Stude63 - 10-30-2007, 08:37 PM
[No subject] - by TonyJSenior - 10-30-2007, 10:39 PM
[No subject] - by Texasrocker - 10-31-2007, 12:01 AM
[No subject] - by 49Stude63 - 10-31-2007, 10:43 AM
[No subject] - by TonyJSenior - 11-17-2007, 09:01 AM
[No subject] - by Ron Ramirez - 11-17-2007, 12:01 PM
Philco 91 Tuning Condenser
