Vibrator needed for superhetero
I need a vibrator for a philco superheterodyn. I took a picture of the back of the radio. I don't know how to upload it. Well I guess my pic is to big to upload. Let me know info. You may need to I can get the right part. Thank you
Vibrator needed for superhetero - by Davetalife - 03-04-2013, 08:59 PM
RE: Vibrator needed for superhetero - by morzh - 03-05-2013, 11:18 PM
RE: Vibrator needed for superhetero - by jontz - 03-05-2013, 11:41 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
