Philco Jr. Model 81 Volume Circuit
Because the set has no AVC, and it has a regenerative 2nd detector, you'll probably need to keep a control at the antenna input. The 2nd detector will give low distortion only for a very limited range of input signal. But, if the set is too loud when it sounds best, you could make the grid resistor of the 42 a pot too. I'm sure there is something wrong on the schematic. The 4 meg resistor at the grid of the 2nd detector makes no sense as shown.
RE: Philco Jr. Model 81 Volume Circuit - by Bill Kinghorn - 03-05-2013, 11:22 AM
