Philco Model 60
Hi
I am working on a Philco Model 60. I am starting by replacing the Electrolytic caps #45 & 46 on the service bulletin #164. I notice that the #45 cap had been replaced before. The schematic shows the minus ends of the caps tied together, the 45 cap minus had been grounded. Should I make it like the print or was this grounded for a reason?
Thanks Bob
Philco Model 60 - by Bob - 03-05-2013, 09:19 PM
RE: Philco Model 60 - by morzh - 03-05-2013, 10:45 PM
RE: Philco Model 60 - by Ron Ramirez - 03-06-2013, 08:53 AM
RE: Philco Model 60 - by Bob - 03-06-2013, 08:59 PM
RE: Philco Model 60 - by codefox1 - 03-06-2013, 09:13 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
