philco 551 clock
have philco 551 clock in poor shape would like any photos of clock mechanism with cover off . if any one knows of schematic or other models with this mechanism would be interested .
philco 551 clock - by ckc - 10-31-2007, 01:11 PM
Philco 91 Tuning Condenser
There are currently 8762 online users. [Complete List]
» 1 Member(s) | 8761 Guest(s)
