Securing 38-1 chassis in its cabinet
I've been looking at the inside of the cabinet and see a narrow shelf below the chassis shelf, extending the total width of the cabinet. It's about 4 inches below the back of the sloping shelf and has two carriage bolts centered in it, 6 inches apart. It's slightly below the hole for the speaker (in the speaker board) but not butting up against it (centered front to back). Looks to be factory installed.
Any idea what this would be for?
Art
RE: Securing 38-1 chassis in its cabinet - by Art Hoch - 03-06-2013, 01:05 PM
RE: Securing 38-1 chassis in its cabinet - by classicradiorepair - 03-12-2013, 07:52 AM
Philco 91 Tuning Condenser
There are currently 6566 online users. [Complete List]
» 1 Member(s) | 6565 Guest(s)
