Model 38-7 Questions
In looking at one of the alignment procedures for this unit, it mentions setting the freq. generator to 470Khz and the "multiplier" to 1000. Bit confused on this one - did the 'multiplier' actually raise the 470KHz or was the scale on the old equipment screened for different multiplier bands?
I won a bid on a Conar 280 generator and should be getting it next week. Had an Eico 324 around '81 in my senior year of high school, but got rid of it long ago thinking I would never use it again. Sigh...
Model 38-7 Questions - by TonyJSenior - 10-23-2007, 03:16 PM
[No subject] - by 49Stude63 - 10-23-2007, 04:27 PM
[No subject] - by TonyJSenior - 10-23-2007, 04:52 PM
[No subject] - by TonyJSenior - 11-02-2007, 10:11 AM
[No subject] - by Don Lind - 11-02-2007, 12:08 PM
[No subject] - by TonyJSenior - 11-04-2007, 08:59 AM
Philco 91 Tuning Condenser
There are currently 4655 online users. [Complete List]
» 2 Member(s) | 4653 Guest(s)
