interchanging chassis and cabinet
Do you think a philco 60 (360 chassis and code 121) cathedrel chassis will fit a philco 37-60 cabinet? I'm not sure if the knob holes will fit , they look squat.
interchanging chassis and cabinet - by Guest - 11-03-2007, 10:59 PM
[No subject] - by Ron Ramirez - 11-04-2007, 10:35 PM
[No subject] - by Guest - 11-05-2007, 12:49 AM
Eico 232 VTVM Schematic
There are currently 8170 online users. [Complete List]
» 2 Member(s) | 8168 Guest(s)
