Philco 112 Bel Geddes for $99
There is a Bel gedes model for sale at an antique store in Yucca Valley. It was marked $450, so I told the owner that it was ten times a realistic price, or maybe five, as the cabinet does not need refinishing. Go get it if you want one.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Philco 112 Bel Geddes for $99 - by radio-Don - 02-27-2013, 08:11 PM
RE: Philco 112 Bel Geddes for $99 - by Jayce - 02-27-2013, 08:46 PM
RE: Philco 112 Bel Geddes for $99 - by radio-Don - 02-27-2013, 09:02 PM
RE: Philco 112 Bel Geddes for $99 - by TA Forbes - 02-27-2013, 10:38 PM
RE: Philco 112 Bel Geddes for $99 - by radio-Don - 02-27-2013, 11:15 PM
RE: Philco 112 Bel Geddes for $99 - by radio-Don - 02-28-2013, 12:19 PM
RE: Philco 112 Bel Geddes for $99 - by 7estatdef - 03-07-2013, 03:03 PM
RE: Philco 112 Bel Geddes for $99 - by FStephenMasek - 03-07-2013, 06:04 PM
Philco 91 Tuning Condenser
