interchanging chassis and cabinet
It will not fit. Chassis holes for Model 37-60 are spaced farther apart than for Model 60; not to mention the smaller dial used with Model 60 versus Model 37-60.
interchanging chassis and cabinet - by Guest - 11-03-2007, 10:59 PM
[No subject] - by Ron Ramirez - 11-04-2007, 10:35 PM
[No subject] - by Guest - 11-05-2007, 12:49 AM
There are currently 9228 online users. [Complete List]
» 2 Member(s) | 9226 Guest(s)
