  • 1 Vote(s) - 5 Average
48-482- Weird Problem
#42
Eric, the treble control is a fairly simple circuit, only 3 parts in it. The control, a .01 cap and a 220pf cap. Looks like perhaps a shielded cable from the high side of the pot to the .01. Does it squeal when you touch the bare shaft or when you adjust it? Check the resistance to ground from the center tap and from the low end. Also did you change out the .01 cap?
Jerry
http://www.nostalgiaair.org/PagesByModel...013637.pdf
48-482- Weird Problem - by Eric Adams - 03-05-2013, 03:46 PM
RE: 48-482- Weird Problem - by Ron Ramirez - 03-05-2013, 05:48 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-05-2013, 06:03 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-05-2013, 10:34 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 12:12 AM
RE: 48-482- Weird Problem - by Ron Ramirez - 03-06-2013, 08:48 AM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 02:00 PM
RE: 48-482- Weird Problem - by Ron Ramirez - 03-06-2013, 02:15 PM
RE: 48-482- Weird Problem - by morzh - 03-06-2013, 02:25 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-06-2013, 02:47 PM
RE: 48-482- Weird Problem - by morzh - 03-06-2013, 03:17 PM
RE: 48-482- Weird Problem - by codefox1 - 03-06-2013, 03:23 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 03:41 PM
RE: 48-482- Weird Problem - by morzh - 03-06-2013, 03:49 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 04:28 PM
RE: 48-482- Weird Problem - by morzh - 03-06-2013, 04:36 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 07:28 PM
RE: 48-482- Weird Problem - by morzh - 03-06-2013, 10:56 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-06-2013, 11:15 PM
RE: 48-482- Weird Problem - by BrendaAnnD - 03-06-2013, 11:18 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-07-2013, 12:00 AM
RE: 48-482- Weird Problem - by Sean - 03-07-2013, 09:26 AM
RE: 48-482- Weird Problem - by morzh - 03-07-2013, 10:51 AM
RE: 48-482- Weird Problem - by Ron Ramirez - 03-07-2013, 12:30 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-07-2013, 03:34 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-07-2013, 05:38 PM
RE: 48-482- Weird Problem - by Arran - 03-07-2013, 08:51 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-07-2013, 09:48 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-07-2013, 10:40 PM
RE: 48-482- Weird Problem - by BrendaAnnD - 03-07-2013, 10:42 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-07-2013, 11:01 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 10:26 AM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 10:31 AM
RE: 48-482- Weird Problem - by Raleigh - 03-08-2013, 12:41 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 12:58 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 01:22 PM
RE: 48-482- Weird Problem - by codefox1 - 03-08-2013, 02:49 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 04:51 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-08-2013, 05:27 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 05:50 PM
RE: 48-482- Weird Problem - by codefox1 - 03-08-2013, 06:27 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-08-2013, 06:37 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 09:56 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-08-2013, 10:40 PM
RE: 48-482- Weird Problem - by codefox1 - 03-08-2013, 10:47 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-08-2013, 11:04 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-20-2013, 04:26 PM
RE: 48-482- Weird Problem - by jerryhawthorne - 03-20-2013, 05:20 PM
RE: 48-482- Weird Problem - by Chuck Schwark - 03-20-2013, 05:20 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-20-2013, 10:07 PM
RE: 48-482- Weird Problem - by Eric Adams - 03-21-2013, 01:00 AM
RE: 48-482- Weird Problem - by Eric Adams - 03-29-2013, 10:30 AM
Philco 89 indicator light.
46-1201 Trip Switch Spring
