Aligning the 40-190
Some info here:
http://www.nostalgiaair.org/PagesByModel...013339.pdf
My dummy coil is around 40 turns of magnet wire from discarded transformer wound on a paper towel cardboard .
You might also want to invest in an inexpensive modern digital frequency meter to check the accuracy of your vintage signal generator after letting it settle in for a half hour. Turn the modultion off while doing the check.
Aligning the 40-190 - by jmac3ky - 03-09-2013, 11:39 AM
RE: Aligning the 40-190 - by codefox1 - 03-09-2013, 12:35 PM
RE: Aligning the 40-190 - by jmac3ky - 03-10-2013, 09:42 AM
Philco 91 Tuning Condenser
