48-1253 just completed
Great job. It's a looker now.
48-1253 just completed - by NostalgiaRadioTime - 02-23-2013, 07:10 PM
RE: 48-1253 just completed - by TA Forbes - 02-27-2013, 10:40 PM
RE: 48-1253 just completed - by jmac3ky - 03-09-2013, 09:02 PM
RE: 48-1253 just completed - by Ron Ramirez - 03-09-2013, 10:01 PM
RE: 48-1253 just completed - by Bill Bacco - 03-10-2013, 09:38 PM
RE: 48-1253 just completed - by codefox1 - 03-10-2013, 10:26 PM
Philco 91 Tuning Condenser
