Any guesses?
Well, DUH! Icon_redface I have that catalog too, but forgot to look in it as it is not stored in the three-ring binder with most of the others I have.
Same ad copy as in the 1935 catalog - not surprising.
I have 1932, 33, 34, 35, 37, 38, 41 and 46 catalogs along with one from the mid-fifties somewhere.
Any guesses? - by Jerry Huelsbeck - 11-09-2005, 11:05 PM
[No subject] - by Ron Ramirez - 11-09-2005, 11:40 PM
[No subject] - by Jerry Huelsbeck - 11-10-2005, 03:36 AM
[No subject] - by Chuck Schwark - 11-10-2005, 09:41 AM
[No subject] - by Ron Ramirez - 11-10-2005, 10:58 AM
[No subject] - by Ron Ramirez - 11-13-2005, 12:36 AM
[No subject] - by Guest - 11-13-2005, 01:33 AM
[No subject] - by Chuck Schwark - 11-13-2005, 12:48 PM
[No subject] - by Guest - 11-13-2005, 01:19 PM
[No subject] - by Ron Ramirez - 11-13-2005, 01:29 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:04 PM
[No subject] - by Chuck Schwark - 11-13-2005, 03:18 PM
[No subject] - by Ron Ramirez - 11-13-2005, 03:28 PM
[No subject] - by Guest - 11-13-2005, 04:05 PM
[No subject] - by Guest - 11-20-2005, 06:20 PM
[No subject] - by Chuck Schwark - 11-20-2005, 08:31 PM
[No subject] - by Terry Judkins - 11-20-2005, 10:58 PM
[No subject] - by Chuck Schwark - 11-20-2005, 11:30 PM
[No subject] - by Guest - 11-27-2005, 07:45 PM
There are currently 10156 online users. [Complete List]
» 1 Member(s) | 10155 Guest(s)
