Oscilator coil for Cathedral 60
Coil I have has an open and damaged secondary (3.4 ohms winding).
Can somebody provide me some tech information about this winding:
- wire size
- number of turns
- widing direction (clockwise?)
- any particular hint?
- drawing?
Oscilator coil for Cathedral 60 - by Guest - 11-06-2007, 11:33 AM
Coil rewinding - by AI2V - 11-07-2007, 10:40 AM
oscilator coil for Cathedral 60 - by Guest - 11-07-2007, 05:31 PM
Winding direction - by AI2V - 11-08-2007, 11:40 AM
Oscilator coil for Cathedral 60 - by Guest - 11-09-2007, 07:21 AM
oscilator coil for cathedral 60 - by Guest - 11-09-2007, 08:38 PM
Philco 91 Tuning Condenser
There are currently 9204 online users. [Complete List]
» 1 Member(s) | 9203 Guest(s)
