Radio Alignment
Guys,
search You Tube for AM radio Alignment. There are quite a few videos that will show you how to align these radios.
Good luck,
Eric
Eric
The Villages, FL
Radio Alignment - by Bob - 04-19-2009, 07:32 PM
RE: Radio Alignment - by jmac3ky - 03-09-2013, 11:29 AM
RE: Radio Alignment - by Eric Adams - 03-10-2013, 01:56 PM
Re: Radio Alignment - by NV3G - 04-20-2009, 12:03 PM
Re: Radio Alignment - by Raleigh - 04-20-2009, 04:28 PM
Re: Radio Alignment - by codefox1 - 04-20-2009, 07:20 PM
Re: Radio Alignment - by Bob - 05-01-2009, 08:06 PM
Re: Radio Alignment - by exray - 05-01-2009, 08:49 PM
Re: Radio Alignment - by kruc - 05-03-2009, 05:22 AM
Re: Radio Alignment - by codefox1 - 05-03-2009, 01:26 PM
Re: Radio Alignment - by Bob - 05-03-2009, 09:57 PM
Re: Radio Alignment - by Texasrocker - 05-05-2009, 02:22 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
