40-150 mystery
Kevin--
I broke the same socket in my 40-190. I did JB-Weld mine back together, but it was unable to withstand the soldering heat. Save yourself some grief... get a new socket. (Fortunately, I used my socket problem as an excuse to run up to SPARK! Museum of Radio & Electricity in Bellingham, WA, just an hour away.)
40-150 mystery - by 37silverstreak - 03-08-2013, 11:58 PM
RE: 40-150 mystery - by Ron Ramirez - 03-09-2013, 08:14 AM
RE: 40-150 mystery - by 37silverstreak - 03-09-2013, 12:39 PM
RE: 40-150 mystery - by DeckApe - 03-10-2013, 05:32 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
