Oscilator coil for Cathedral 60
Thanks Pate for taking your time providing me an answer.
One last question: what is the direction of winding looking at the base of the coil - clockwise or counterclockwise?
Oscilator coil for Cathedral 60 - by Guest - 11-06-2007, 11:33 AM
Coil rewinding - by AI2V - 11-07-2007, 10:40 AM
oscilator coil for Cathedral 60 - by Guest - 11-07-2007, 05:31 PM
Winding direction - by AI2V - 11-08-2007, 11:40 AM
Oscilator coil for Cathedral 60 - by Guest - 11-09-2007, 07:21 AM
oscilator coil for cathedral 60 - by Guest - 11-09-2007, 08:38 PM
Philco 91 Tuning Condenser
