My Philco 38-116
And now a couple pictures of the chassis:
My Philco 38-116 - by Jayce - 03-11-2013, 12:31 PM
RE: My Philco 38-116 - by Jayce - 03-11-2013, 12:38 PM
RE: My Philco 38-116 - by jerryhawthorne - 03-11-2013, 01:15 PM
RE: My Philco 38-116 - by Ron Ramirez - 03-11-2013, 04:16 PM
RE: My Philco 38-116 - by Art Hoch - 03-11-2013, 05:19 PM
RE: My Philco 38-116 - by Jayce - 03-11-2013, 10:40 PM
RE: My Philco 38-116 - by Jayce - 03-12-2013, 01:11 AM
RE: My Philco 38-116 - by Gene Pederson - 03-12-2013, 05:54 PM
RE: My Philco 38-116 - by Jayce - 03-12-2013, 09:25 PM
RE: My Philco 38-116 - by jerryhawthorne - 03-12-2013, 10:08 PM
RE: My Philco 38-116 - by Jayce - 03-12-2013, 11:29 PM
RE: My Philco 38-116 - by jerryhawthorne - 03-13-2013, 12:13 AM
RE: My Philco 38-116 - by jerryhawthorne - 03-17-2013, 02:40 PM
RE: My Philco 38-116 - by Jayce - 03-17-2013, 05:07 PM
RE: My Philco 38-116 - by Arran - 03-18-2013, 08:36 PM
RE: My Philco 38-116 - by jerryhawthorne - 03-19-2013, 08:04 PM
RE: My Philco 38-116 - by Jayce - 03-19-2013, 09:18 PM
Philco 91 Tuning Condenser
